So I'm ready to Overclock
16 Oct 2011
Or I think so.
Gelid Tranquillo just installed
i5-2500k.
hd5870
MSI/P67A-GD65-B3
650W psu
2intake 1 exhaust fan, plus the stock Gelid fan.
I've overclocked before but not all day, just to familiarise myself with the bios and to say I'd done it.
I've seen people just change the multiplier to say 45 for a 4.5ghz overclock but I have no idea what voltages are good to have. I also just set everything to auto but this lack of technical capability I don't trust, so I waited to get a decent cooler. Anyone got advice on how to overclock safely (besides temps of course)
I'll be running BF3 which will take the most CPU strain and I tend to play a few hours on end.
All you need to do is up the multiplier to whatever you want and adjust the voltage until it's stable. Make sure you have CPU-Z, RealTemp and Prime 95 installed first though to save some time.
4.4ghz with CPU core voltage 1.344 (by CPU-Z)
Idle temps are 40 celsius by speedfan, which is 4 or 5 degrees more than 3.3ghz....blue-screened when streessing all cores in Prime95.
hmmmm
hmmmm
Is the blue screen a error xxxxxx124. If so then its probably related to CPU Voltage.
Check if the Vcore drops when underload. Maybe watch VCore in CPU-Z while runing Prime.
Didn't take them down sorry, I will if it happens again. Right now I'm prime95 at 64-68 degrees, 1.320 Core Voltage and it's not blue-screened in 10 minutes. SO i'll keep it running longer. I did change the CPU voltage in BIOS to 1.28V though after the last blue-screen.
Yep, bluescreened again whilst running CSS for about 45 minutes. Don't know what happened but it was definately a xxx124 error.
4.4ghz
Core V set to 1.28
Was getting 1.32 under prime95, hard to know what it was during CSS game.
Intel says no more that 1.38 VCore, but its just a guess tbh, definitely no more than 1.5 though. Try 1.36 VCore next.
do they were??
i would say 1.4 is safe. intel have not given a safe volt limit
just bump up the volts by 0.02 and try again. or make a big jump then try lowering it
http://forums.overclockers.co.uk/showthread.php?t=18287345
take a look at that thread loads of people running them at 1.4
each chip is different tho.
Tells you here about the voltage they say, under the overclocking guidelines. I myself have 4.7ghz at 1.344 I would not go over 1.38.
https://www.overclockers.co.uk/showproduct.php?prodid=CP-360-IN
- Do not exceed 1.35-1.38v core voltage, doing so could limit lifespan of the CPU
- Do not overclock with BCLK, again doing so could limit lifespan of the CPU
- Recommended memory voltage is 1.50v, so make sure to run your memory at 1.50v, higher could limit lifespan of the CPU
- These recommendations come from OcUK and Intel, your warranty is un-affected but we highly recommend you adhere to the above to make sure your CPU lifespan is un-affected
- All Sandybridge CPU's worldwide should be run at the above or lower voltages, no higher!
That's where it says
lol
sorry forgot intel wrote that.
look at the pre overclocked bundles ocuk do......
intel will not be happy after writing that thread
and another note sandy bridge boards do 1.65 volt memory.
and you can also overclock with bclk http://hardforum.com/showthread.php?t=1578110
Mine does 4.7ghz stable with prime and ibt without going near 1.38. I just prefer to stay in the guidelines when doing stuff like this.
4.7ghz at 1.344 :)
4.7ghz at 1.344 :)
you got a good chip then.
They are ocuk's guidelines not Intel's
they have also sold chips with a granted over clock of 4.8 @ 1.4 volts so they went back on there guidelines
Ahhhh I see, so what is the guideline from intel? Or do they not give guidelines. I must admit I have seen posts with people on higher volts then 1.4 even and they all seem fine. But I am a worry guts :p
There are no guidelines from Intel yet. There is for older chips.
Look at post 12 with the link to a thread i started. Most people are running them around 1.4 including myself.
