...how on earth do you choose which to go for? I'm looking for a new CPU and mobo for FSX and I think an i5 2500K is what I'll go for. Under Intel Motherboards there are 7 1155 sections listed. How can I narrow down my options? Don't have a clue!
I would just suggest using 8GB of RAM right now. Unless you need more? Gaming doesnt use more than 4GB most of the time so...
I have 8GB RAM and trying to run 2 VMs uses it all up! Not enough..
When I upgrade my rig I'm even contemplating 32GB!! 16GB will be a minimum.![]()
What OS are you using? This may be more of a limiting factor than the motherboard.
Eor example.
Windows 7 Home Premium 64bit can only use 16Gb of Memory.
No preference on the type of RAM. I'm no expert so happy to take recommendations. I'd like to use Hyper-V in Windows 8 for a home lab so the 32Gb would come in very handy.
