This is where you need a battery operated dash cam - i have an Anker Roav and it bings every time its disturbed. Definitely a deterrent for people trying to mug you off!
Every time mine goes in for a service, i quickly check all the footage soonish afterwards.
I'd be expecting them to wave that £95 as well.So the service manager did phone me back, he was very apologetic and instantly offered me a full refund.
Had a good chat with him actually, he said how he first checked the CCTV which shows he went no where near the glove box, he also cant see him changing the fuel filter. He then asked the tech if he had fitted the items charged for and he lied and said yes, only when shown the CCTV did he admit he only did the oil, oil filter and air filter.
So im going to get the lot done again anyway, only £95 for all the parts.
Wave what £95, thats me buying the parts and doing it myself, the car wont be going near them again.I'd be expecting them to wave that £95 as well.
I'm going to buy the oil, oil filter, pollen filter and fuel filter and get them all changed just incase. The air filter looks brand new but that's easy to change so I'm guessing they just couldn't be bothered with the stuff that takes longer than a couple of minutes.
Ford, doesn't surprise me. This is why you should always ask for the old items back. Even if it means throwing them away yourself.
Not had any issues personally, although my approved Ford Service centre is part of a Hyundai dealership (who used to be a Ford dealership years ago)Heh, Ford. The same company who on the MOT document added an extra digit onto the car mileage. That caused a headache when selling it.
Major service as in the OP.Was it actually a Major Service they did, or was it a Motorcraft Service? (in which case they change either the air filter or the pollen filter, but not both unless you pay extra)
Turns out the fuel filter was done, had my friend have a look, oil filter was done as well looked brand new. Doesn't look difficult to do just a standard filter sticking out the bottom like any other car I've had.not in the least bit surprised to hear this, dealers are poor in general.
rough running on a 2l tdci ford chances are the fuel filter has never been changed in its life. their a bas to bleed up afterwards. Mk5 Mondeo oil filters are also a pita. stupid fragile housing buried under all sorts. and don't get me started on a bulb change on a mk5 Mondeo. had a proper swearing session doing mine.
Vivaros on the other hand are a doddle and I can do a service in under 30 mins start to finish including stopping for a cuppa.
Had the same issue on a Mk4 Mondeo, the pollen filter is a nightmare to get at so it gets "forgotten" by a lot of servicing places. My car had been service by a local garage dozens of times (240k miles) before I bought it and I immediately noticed that my fan only worked at the highest setting. After a 10 sec Google search I found that a blocked pollen filter was the usual suspect so after several hours of blood, sweat, tears and copious amounts of swearing, I replaced it and the fan worked fine.
My guess was that the blocked filter was the original one from the cars manufacture, thats how many times it'd been missed.
That's exactly the issue. Half an hour with YouTube instructions. Looking it up it looks like you have to remove the entire glove box? It's clearly a faff and easy to see why garages would just not bother and try and get away with it.Really? I've changed my mk4 Mondeo pollen filter a couple of times and while it is inconvenient and fiddly, youtube helped me do it in under half an hour. I don't have any notable experience working on cars. I wouldn't have thought it'd take more than 10 mins for a mechanic who does it every day.
I changed my pollen filter and it was a 5 minute job without having to watch a YouTube tutorial.
https://youtu.be/_xOl_BRhC8A
Couldn't get much more simple than that.
