Thats assuming I put the titans to work on Folding, I like to support a few projects and it depends what the best fit is, in the past Seti has been a Nvidia stronghold with GPU being a better fit than CPU
But F@H is better served by 4P monsters than GPGPU from a cost/wu perspective even with the new GPU wu's
Say 4 Titans get 80K each, even if they get 100K and assuming the only thing you have to buy for the rig is the cards, thats 400K ppd for £4K or 100 points/£
A 4P system will cost you £2K and even if you don't overclock it will net you twice as many points for half the price. And the power costs will be about half as well.
The only reason I have a 7970 is to play the odd game and because I like tech, the fact its folding is because I'm a beta tester and like tech.
Weebeastie used to be a gpu folding monster because folding was primarily a gpu platform in those days, then it switched to a Boinc rig (mainly Seti) because thats where it did its best work. (And I folded on the 970X in a VM)
Things haven't changed much now, I'll probably put it on Seti if the client improves, or GPUGrid or some other project that takes advantage of the power of the Titans. I will probably run the Core 17 client to help test it for a while and benchmark etc. But will always return it to what it runs best at in the end.
However with all the change to OpenCL happening around the place it may be that things start to shift to the AMD gpu side (about time imho) then I'll have to rethink.
