Software to test temps, load etc?
You might just had a volt hungry chip with bad temps! :(
See if they will replace it, that chip isnt stable at 4, like you paid for it to be.
indeed.
i've just completely taken the system apart and rebuilt it with reapplied paste (this time with a thin layer as normal then a small extra blob for kicks) with almost no drop in temp, maybe 1 degree. Max is still hitting 87C...
I think I have a bad chip ;/
I'm going to get back onto support and try to get it swapped out.
I may as well return the whole bundle as it might be something else doing it.
Thanks for the help guys, much appreciated.
yeh this thing is roasting.
although the good news is that during 3D rendering (99.9% of the time this is what this system will be doing) temp hasn't gone about 79C and it's stable, no crashes. Previously I was getting crashes with every single render.
I'm almost considering not returning this if it's going to be stable at 79/80C....... if it works...? I'd rather not be without a workstation for 2 days! (I do have my old PC though...). argh, decisions...
Send it back! Its not right! Besides, if its got the extra heat it decreases the life expectancy of the chip...
ok im convinced :)
i'm sending the bundle back! now trying to get through to system support before 5:30 lines close. dont want to delay another day... ;/
cheers lads
ffs systems support is closed now, 5 mins early! engaged the last hour... i guess i'm going to have to arrange this tomorrow morning, hopefully we can get it sent out tomorrow and not wednesday...
old system is an sx38p2 shuttle, QX9650 @ 3.0, 8GB DDR2. Not a bad machine but was getting really ropey, hence the new build.
edit: trying to call main tech support line. maybe they can action this tonight.
no idea never really tested it thoroughly to find out why. it works well enough for most things. more a case of it being too slow for my needs than not working tbh. i'm gonna have to rip the HDDs and GPU out of this new build to get it to work again now. sigh.
I feel sorry for you man, but still a quad 3.0 ghz isn't slow!
When you finally get your system up and running are you going sell the qx9650?
thanks mate... i'm pretty ****ed off tbh. really hoped (and expected) this system to work. they do say they test it all first. surely they'd have seen these crazy temps when testing?
i won't be selling it, no. i've got that one QX9650 machine and two Q6700 machines as well, in a network render setup. Should all work nicely when this new rig finally works!
They do test the systems... I don't know why they didn't pick up the temps though...
Im sure you will be up and running with your 4.0ghz i7 in no time :)
Why didnt you OC the 9650? Could probs get 3.5, maybe more out of it...
no idea how to OC tbh! absolutely no idea. would rather a stable and slightly slower system than one that cooks itself to death.
besides it's already running at about 100C under full load. after today's discoveries about temps and all that business I'm starting to worry about that one too! although it's been stable for a year and a half now, not a single BSOD.
brb. gonna stick this gear back in the old system and see if it still boots ;)
100 degrees is crazy!
What case did you say you had?
You should seriously get a better heatsink and sort out the cooling on your 9650, im surprised it hasn't cooked itself!
