- 12 Mar 2022
- Bournemouth
We are budgeting around 10k for a solar system. We have had varying quotes and found a company I am happy with (local company, their own installers no subcontractors) but need to decide on a system before I negotiate on the price.
Our property is south facing and has space for up to 20 solar panels ( 8 on the front pitch, 8 on the back pitch and 4 on the garage roof) no shading or obstructions on the south coast, Bournemouth.
Our typical usage is around 4,000kwh/annum but looking to increase running a pool filter and in the next 5 years we will be getting 1 maybe 2 EVs.
So my questions are:
I’ve been quoted for 12 (8 and 4) JA 365 panels which would give us about 5,000 kWh coverage.
I’ve also been quoted 20 of the same panels which would give 7,000+KWH
There is also an option to go with sun power 400w maxeon 3, which is more investment but better warranty and performance for longer.
I’ve not thought about a battery for the moment as they only supply the solar edge 10kwh or Tesla power wall 2, however would it be better to use less panels and get a decent sized battery?
Our daily usage is about 10-11kwh at the moment but that’s not running the hot tub and pool yet.
What would be your advice on steps forward? Is it best to invest more into more premium solar panels because adding more is expensive or just budget for 5 ish KWh and that would be ok when we add EVs?
I’m on a fixed rate 17.8p tariff until December so don’t want to lose that for the moment. Also I don’t want to be spending forever tweaking tariffs to get the best return on charging in off peak. A set and forget would be ideal.
There is an immersion tank as well so will get a solar edge hot water thing or an eddi.
I’ve been through lots of the threads here and it’s all been invaluable getting to this point. Very much appreciated
