- 21 Jul 2005
- Officially least sunny location -Ronskistats
12.9
I joined but need to message about getting rid of account, no easy way to add my system.i think some people stopped adding size etc etc when we all joined pvoutput........
you can add the data manually, thats what i did for a whileI joined but need to message about getting rid of account, no easy way to add my system.
I think I'm pretty well aware of the what affects what when it comes to solar panels, I really don't think we need information overload that a lot of people won't understand, there's something to be said for keeping it simple
Anyway a meagre 12.7kWh from who knows what equivalent south facing panels at the perfect angle, as they are at different angles and orientations
PS. The point was someone could have 20kW or 2kW of panels, with no indication of system size the figures are meaningless really.
It will come off soon enough…….13.3 today, not too bad I suppose, whats annoying is my battery at 8.9 out of 13.5 stated kwh is saying 96% lol, got a frustrating bit of bird poop on panels as well that rain wont get
If you meant me I would have waited probably til I could have sorted more space in back garden for some panels as well, something that could be rotated/tilted perhaps but with no roof to get in the way and being lower it probably wouldn't be needed.If you had your time again would you just fill the roof on both sides? 8+ KW install might do ok over winter.
I am regretting battery storage atm with all the SOC issues im having, considering it has a gateway home backup system the battery being unreliable is a joke, atm for a 13.5kw battery that from 5% flat (thats the reserve) to 100% ive seen 14.7kwh and ive even seen during flux charge period 15.7kwh being put into the battery (its stated 13.5kw on datasheet but says 15.96 in portal) and based on that info with 4.7kwh left in the battery its telling me there is 72% battery left.
Thanks for the info. Will have a read. Debating how big to go in a self build. Will have air source heat pump so frankly the bigger the better. Pitch will be SW to NE in the south west of England. Roof space on the southern side should be roughly 65 SQM so in theory I can fit 20+ panels to make up 8kw. My only thought is to add panels to the NE aspect, maybe 4kw, which in practice might be more like 2kw effective. 20kw battery would get us through 8-9 months energy free and hopefully in winter we can make some dent in the bill.If you meant me I would have waited probably til I could have sorted more space in back garden for some panels as well, something that could be rotated/tilted perhaps but with no roof to get in the way and being lower it probably wouldn't be needed.
You're still gonna get many days where you generate nothing or just a few kw.If you had your time again would you just fill the roof on both sides? 8+ KW install might do ok over winter.
The thread over on forums is "Battery Calibration" as it started off with me not getting the message the battery calibration had been completed after a few days but all the info on that is in there as well, apparently GE said it was done but somehow didn't get the message.Thanks for the info. Will have a read. Debating how big to go in a self build. Will have air source heat pump so frankly the bigger the better. Pitch will be SW to NE in the south west of England. Roof space on the southern side should be roughly 65 SQM so in theory I can fit 20+ panels to make up 8kw. My only thought is to add panels to the NE aspect, maybe 4kw, which in practice might be more like 2kw effective. 20kw battery would get us through 8-9 months energy free and hopefully in winter we can make some dent in the bill.
I like the idea of a ground install but my plot is 650sqm so not quite big enough without shade from trees and buildings. I may be able to use the garage for the 4kw as it's aspect will be E rather than the NE aspect of the house, and would presumably be more efficient.
