Solar panel production figures
I managed 0.28 one day last December.
That was really dark and raining from memory
I guess the simple hurdle is based on array size and inverter minimum. You would hope the inverter needs to at least cover its usage before it properly fires up.
Of course its using minimum grid power when PV isn't generating but I assume more circuits etc need power when its switched into active mode.
The SolarEdge system certainly kicks in a little later than the Victron system, so that is most likely the cause of zero days, it just doesn't get up to the minimum required to start up.
2.10 so far :(
But this made me laugh a little
5.1kwh today.
First full day with new upgraded system from 4.5kw to 5.2kw.
Still pretty grim, looks to be even worse tomorrow.
Edit: Sorry upgraded to 5.7kw. It's been a long ****** week......
1 hour from midday and we're generating nothing. Unless it somehow brightens up, today will be another zero generation day.
