- 25 Nov 2009
Apologies… bizarrely I thought you had a sig, now I realise on mobile they don’t show up…It's in my signature, but presumably you can't see that, it's currently 8.74kWp
You may remember me asking at the time if I should’ve had a 5 or even 8kW inverter… anyway, I’m likely having the same company install a heat pump but I used that as leverage to come and fit a suitable sized inverter like they should’ve done 15months ago… anyway, how much can I reasonably expect my output to change? Currently I make 5500kWh/year.
Are the panels south-facing? If so you might make another 1000kWh or so. A 3.6kW inverter on nearly 7kW of panels though. Some installers just take the pee!Perhaps the other thread is better suited… I’ll ask anyway.
I have 6.7kWp panels
3.6kW inverter
5.12kWh battery
Newb question - is that 40.6 total or 40.6 plus the 30.5 that was exported?...and we are back! 40.6 today, 30.5 exported.
40.6 generated, of which 30.5 of that was exportedNewb question - is that 40.6 total or 40.6 plus the 30.5 that was exported?
Used £8….exported £4540.6 generated, of which 30.5 of that was exported
Edit: I've used £18.01 of electric and exported £75.93 so far this month
