Solar panel production figures
I'm currently at 32 kWh for the month, that's an average 8 kWh a day and that's December's predicted daily averages, the rest of the week looks just a bad.
Going to need some good weather to catch up!
10kwp array, projected 5.6, generated 3.5, exported 0.7. Good day right? :p
Compared to my 2.29kWh from my 12.7kWp array, yes :/
I'm on 10kWh total so far, so you can pipe down! :p
I'm on 17 for the month so 4.25 per day.
Target for the month is 220/7.44 per day. The highest prediction I have over the next week is 6.4 and I've been trending below solcast by 30%-50% per day :( .
Edit: on the plus side I am 267 up on my yearly target and I didn't even have my installation for the first 15 days of the year.
Had my system on and running a few days. West array got installed a little lower than per the drawings and I think might be suffering a bit more from shading than was expected. 6.16 kWp system installed (6 x 440W panels almost due East, and 8 almost due West).
Probably only on for 2kWh generated today, just outside Glasgow. Been a dismal cloudy few weeks here lately but I did maintain ~1kW for an hour or so which was nice.
What are the three numbers y'all are reporting?
@shroomz you've got quite a while to go until you see significantly better numbers, with winter on it's way.
Import, export and actual generation are the most likely reported numbers
PS Probably on for my worst day this side of summer, 4.3 kWh generated.
Indeed and much less than you regardless anyway even in the summer :D.
I think next time I'd do this myself following your log.
Even at this darkest time of the year it has run my heat pump from 10am up until 10 mins ago so can't complain too much
Let's see, on the 27th, a Sunday i got 16.1 kWh and since then output was atrocious with only the 31st at 7.3 kWh even coming close to half that 16.1.
Last 10 days total production of 32.1 kWh. So grey, so overcast, so dim.
Looking at the weather forecast for the next two weeks, it seems to be rinse and repeat.
I've generated 4.3 kWh, which is my worse day since 11 March, but if I look at just what the garage and SE system have done which is all I had back in March, then I have to go back to the 20 February.
I'll update the full stats later, as currently exporting.
