Solar panel production figures
Dreadful day, pretty much joint worst day of the month.
SolarEdge: 0.5 kWh
Garage: 0.81 kWh
North west roof: 0.73 kWh
House rear wall: 0.11 kWh
Peak power was 1.66 kW at 11:28
Total generated today: 2.15 kWh
Total exported today: 7.118 kWh
Total imported today: 24.767kWh
4kW coming in at the moment, so far I've generated pretty much double yesterday's, and it's only 10:23
Clouds about though.
I’m generating 1.2kw at the moment and we’ve generated as much as yesterday already.
On the flip side the heat pump has kicked on and is also drawing 1.2kw at the moment so the battery is not charging!
@Gav_r26 I do appreciate why, and it's better than nothing, but I do wonder just how well it would work if put to the test.
No fear of me putting it to the test. I absolutely hate heights! I'd imagine it would be fine, although he'd probably fall a bit due to momentum to start with. You'd like to think they've thoroughly tested it though.
Producing a whopping 61w at the moment despite blue sky. Is an inch of snow on the panels though lol. Can see it melting off the neighbours panels though, so hopefully might generate something later.
