Solar panel production figures
The 12 on the garage, are 10 degrees, the 28 on the house are at 30 degrees, the 3 on the rear wall IIRC are 84 degrees.
When the sun is low, I do suffer quite a bit of shading from neighbours and a tree, once the sun gets a bit higher in the sky it will really pick up.
Ah makes sense. Won’t be long until you re smashing it
Did better than expected, with a peak in to the sixes.
SolarEdge: 2.4 kWh
Garage: 2.2 kWh
North west roof: 2.11 kWh
House rear wall: 0.94 kWh
Peak power was 6.19 kW at 13:08
Total generated yesterday: 7.65 kWh
Total exported yesterday: 14.01 kWh
Total imported yesterday: 31.47 kWh
