- 25 Mar 2004
- Fareham
They had done no site visit ahead of time either, so yes scoping out what goes where was part of it.
The givenergy dongle does not work on 5Ghz, I had to disable it on my BT router (which doesn't let you split out the bands) and then re-enable once connected.
Same for the solis equivalent.
I haven't been brave enough to re-enable 5ghz either in case it messes it up.
It's on an access point though not my main router so not really neefing much else only running on 2.4.
Not sure why you'd need to disable the 5g at all. The 2.4 only device would only see the 2.4ghz network.
I've got a ton of IoT devices that are 2.4ghz only, not had any issues with my hybrid network (Deco mesh).
Same with the growatt one, although it works fine with the dual band tplink "Deco" access points, the only issue i have is that if the server at the other end goes down for more than about 15 minutes (which it's done twice) I have to turn the access points off to force it to reconnect as it decides that no response from the server = no internet and gives up trying after a few attempts. So turning the wifi it connects to off gets it to reset the attempts.The givenergy dongle does not work on 5Ghz, I had to disable it on my BT router (which doesn't let you split out the bands) and then re-enable once connected.
Three days in total - although that was partly us (we were getting new roof fitted at same time, so needed to do the roof, then the batteries/inverter were a few weeks later
Do you set your batteries to a fixed charge amount (ie grid charge to 50% overnight at cheap rate)?
Also do you adjust this regularly or just broadly with seasons?
