- 20 Jul 2007
- A sunnier or damper area than Ron-ski....
Heheh!Oh got it house plus 2x EVs, I was imaging 120kwh of home storage, makes more sense now![]()
On low solar generation weeks/months you'll be doing a full charge from the grid, but it really makes a difference having very sunny days in the days with less daylight hours, as it will keep the batteries at a higher state of charge, seeing you through to the evening.
Did you stick with Go or move to Go Faster?
Went with Go - don't think I can get the Intelligent Octopus until the Tesla arrives....
Anyone able to recommend someone in the southeast that can cover West Sussex?
Best quote I’ve had so far is just over £11k for an 18 panel install which seems less than awesome.
Stick with Givenergy - the missing cables are the fault of the installer, not the supplier. It pretty clearly says on every order that you need to order appropriate cables.I had an old work acquaintance contact me yesterday, he was due to have the following installed on Friday.
He has been given some story about not being able to get one of the battery cables, and now his installer wants to fit the following, we don't know for sure but are presuming same, or similar size battery and inverter.
- 15 x Perlight Solar Panels 400w Black Mono
- GivEnergy 5kW Hybrid Inverter
- G2 GivEnergy 9.5kWh Battery
I suggested he pushed for the GivEnergy system, but only because I know it integrates with Octopus who he's with, and I don't know much about Fox.
- Perlight Solar Panels 400w Black Mono
- Fox H1AC presumed 5kW Hybrid Inverter
- Fox HV2600 presumed 9.7kWh Battery
Does the Fox system integrate with Octopus?
Which is the better system?
Is one significantly cheaper than the other?
He's asked me not to disclose the cost, but its steep even for now, he was quoted early July.
11k for 18 panels does that include a battery? If not then that is expensive.
Solar Dynamics are based in Horsham and should cover your part of the world.
The Fox inverter has the full 5kW charging/discharging, so that's a big plus for that compared to the Givenergy inverter.
I just spoke to them, they confirmed we're getting EPS. phew!We had a very short power cut today. We can't afford to lose our heating and office in a power cut so we specifically requested islanding. Is it possible to tell from the schematic/proposal if batteries will definitely power the house in an outage? (I'd love to share the diagram but I don't have a website to share it from.)
Edit: they said it would, but I don't trust so easily!
Prices are just ridiculous right now it seems. What's the point in paying so far over the odds? I'll wait until things are a bit more sensible.
Inflation is running at 10%. Prices are only going one way.Prices are just ridiculous right now it seems. What's the point in paying so far over the odds? I'll wait until things are a bit more sensible.
