- 21 Jul 2005
- Officially least sunny location -Ronskistats
19kwh today, was good till about 5pm.
Thanks - I agree. Seems a bit unreliable. I am looking at Geo Solar II monitor. Anyone used one of those? ThanksWattson is just a clamp meter such as your provider may have offered in times past. Goes on the incomer but is pretty useless with panels as it's unable to differentiate import from export.
Almost snap here in Cambridgeshire, 18.9 was going good until the end of the day. Waiting to see how the coming months are as it my first winter with these19kwh today, was good till about 5pm.
If you have a smart meter you can use the loop app only shows 1/2 hour readings of usage but you do get access to the last years data which I’ve since copied for future planningThanks - I agree. Seems a bit unreliable. I am looking at Geo Solar II monitor. Anyone used one of those? Thanks
Think 0% VAT is for a number of years so you're safe.Might calm things down for a while at least! Hope she doesn't drop the zero rate tax any time soon though!
The loop app seems to work reasonably well, but doesn't let you put your actual rate charge in so its annoyingly alway off on the cost side of things
Still waiting on my G99 here before the install kicks off, annoyingly slow!
very true, but you know that 20% will go straight on as soon as its revoked...0% VAT rate made no difference to most new quotes...
0% VAT rate made no difference to most new quotes, only those that were already agreed at the 5% rate. The rest just gone straight into the installers pockets, while they raise the price of equipment in line with demand.
At retail prices (inc VAT) you can buy 5kW+ of panels, 5kW GivEnergy HY 5.0kW inverter, GivEnergy 9.5kWh battery, all the mounting hardware, safety equipment, and other sundry items, down to the warning labels for £9.3k, take away the 20% VAT and that is £7.77k, yet somehow installers are quoting £14k for these size installs and smaller. Even if you take into account scaffold etc. they are still taking the pee, making easily £4-5k+ on a single day job for 2-3 people.
Just need to source some kit, put a few queries in but guessing stock is hard to come by. Anyone have recommendations?
Question.
Is a Voltage optimiser necessary/essential/worth it?
Had the same note but for a council much further away. I've signed up just to entertain the process. Not holding my breath!Had a letter today from Hampshire County Council regarding solar install through a buying scheme called Solar Together, will register interest to see what they can offer.
Can anyone recommend a solar installer for Hampshire that I can get other quotes from to make comparisons, thanks.
Were useless from what I found, even more so now you can't get parts for love nor money.Had a letter today from Hampshire County Council regarding solar install through a buying scheme called Solar Together, will register interest to see what they can offer.
