- 25 Mar 2004
- Fareham
I've had a quote back but I think they want too much:
3.9 kw system (10 * 390w Trina panels) with no battery - £5.8K (string inverter) or £6.4K (solaredge inverter).
Same as above with string inverter + 8.2kwh Givenergy battery - £9.8K
Same as above with string inverter + 13.2kwh powerwall - £15.6K
That sized solar system vs cost seems overpriced for just 3.9 kws, and the battery quotes don't seem great either.
Still pending a quote back from someone else. May need to seek a 3rd or 4th opinion. I'm definitely wondering if the gov will put forth some incentives in the next year or so to cheapen the installs a bit.
I actually think this might be the best move! 2 batteries in tandem, enough capacity to charge up overnight on a cheaper off-peak tariff, predictable energy costs all year round.
I wonder if this also means you don't have the same levels of paperwork, and the DNO things etc as well, after all it's just some batteries on site
16kwh or so should be enough to basically go the whole day, assuming smart about usage.
Powerwall is interesting as well because it lets you use the Tesla Energy Plan - obviously it's a huge cost, but with the TEP you appear to get the same import and export rates all the time, and it turns your whole house into a giant UPS basically. https://www.tesla.com/en_GB/support/tesla-energy-plan-faqs?redirect=no - huge investment though and still a multi-year payback, especially as you need panels.
Indicative pricing of Tesla plan is very good, you get more for generation, but unit rates are a bit higher than pure off-peak charging.
I know someone who has just had 15kWh of batteries installed at only £5.7k including inverter and charge controller etc. Costing him £1.12 to charge vs £4.50, so a saving of £1233 per year based on the peak rate at 30p, he uses about 19kWh a day but it's trying to reduce some peak use and shift that as well.
