Well the mob that did my initial installation finally got back to me, they won't touch anything to do with my plans for a 2nd string unless they do everything.
They specifically called out the fact they didn't supply the equipment as a reason. A verbal quote of about £3k to install 6 panels on a south facing wall. Good access, little scaff needed (if any, but sensible to use scaff), very easy cable run to the inverter.
I tried to get them to quote for a 2nd string a year back at the same time as a heatpump quote, and they just delivered the heatpump quote and went quiet on the extra PV. (I didn't progress the heatpump after a heat loss survey but that's another story.)
Oy.
Reading through
MIS-3002 I appreciate that there are many considerations and data that needs to be calculated and provided to obtain the MCS certification, as well as the obvious design and installation particulars to ensure it's compliant. However, there's so much in that document that the installer didn't provide to me (that I didn't know then, that I do know now!) so I'm even more irked at their response. The calcs they provided me for example bear no relation to the actual performance, I didn't get any datasheets or system layout docs prior to signing. I did get some of these once the system had been commissioned.
From that document it
does seem that a Solar installer
can install equipment they didn't supply when operating as an MCS Contractor for a client with a design. However I'm willing to bet me amending the existing design doc with my crayons to show the 2nd string probably won't cut it...
So what to do?
- Do I suck it up and shell out £3k+?
- Keep gradually accumulating shiny new PV parts in the hope I can find an installer willing to undertake?
- Or train, get MCS certified, register myself as a competant person and just do the damn thing myself out of spite?
