Permabanned
I got my SanDisk Extreme Pro 512 USB today , click on to view drive its only saying 465GB ?
Is this normal
Is this normal
Yes! There will be some bios/driver data on the drive, operating system stuff etc
It's probably mainly the difference between MB (1 = 1,000,000 bytes) and MiB (1 = 1,048,576 bytes).
That's not the issue.
This is the issue. Capacities are advertised using base 10, but binary uses base 2. So they have the same capacity but whether you read the value as base 10 or base 2 will show as different numbers.
And it doesn't help that Windows displays MiB but labels them as MB (but that isn't unique to Microsoft).
