dailytech said:Consider a typical computer that writes 120 megabytes per hour to the hard drive. On a 32GB solid-state NAND drive, wear leveling would distribute this data over the entire drive -- it would take 267 hours to fill the device once. Even on a multi-cell flash device, at this rate it would take no less than 150 years to burnout all the bits on the SSD. Single-cell drives are capable of ten times as many writes.
Unsurprising to be honest, the biggest market initially for these is going to be mobile devices - PDAs, laptops & MP3 players where the low power consumption and shock resistance will be most useful. So it makes sense to go with interfaces which make integration into existing products easy, that way you don't need someone to go through a whole product design and release cycle before you (as a manufacturer) start supplying drives in bulk.manoz said:Not available in SATA though?
