Yeah it's a massive leap, and that's coming from a Vraptor owner! That being said considering the price of SSD's I'd personally considering getting a smaller SSD like a 120Gb and installing your games on the raptor.
so. The sugegstion is, leve the os on the raptor, then put all programs on the SSD, cos its not just games, its AutoDesk as I do automotive and formula 1 design
Go for SSD for speed - no question - but under no circumstances store any important data on them. I've had two Vertex LE drives and now a Vertex 3, with both the former failing completely and the latter regularly bluescreening despite updating to the latest firmware. I also built a machine at work including a Vertex 2 and that failed within two months. If you cloud important documents with Dropbox, reference link your My Documents folder and AppData (for video game saves) to another drive and regularly system image your drive you'll be fine.
When paying £300+ for a drive (which the first was at the time) you expect them to at least have a life expectancy of 2-3 years. Perhaps it's just OCZ but I definitely don't trust SSDs at the moment.
It's just OCZ. Get a Crucial.
also, another silly question, how much differnce is the speed between standard drives and raptors?
Ive got a160GB Raptor installed and am consiering an SSD. Is this a serious leap forward in terms of response time and speed?
Mobo is a Asus P5Q Pro. Does it support sata 3 as cant really see it on the specs sheet...
Thanks
Kai
If you mean standard HDD's then a modern 7,200RPM drive, such as the Samsung F3 1TB, has similar performance to the WD velociraptor.
so if my Mobo only supports SATA2, I take it that I can still put a Crucial solid state drive on there?
Yes, but you'll be limited to around 280MB/s.
