SOLVED!!!! Blue screen when setting OnChip SATA to RAID
26 Jun 2010
Hartlepool
I've just installed 2 500gog F3's in raid 0, but when I boot to my Hitachi system drive windows 7 loads until the welcome scene, then it Flashs blue then reboots.......
PROBLEM SOLVED !!!!!!!!! at last
Cheers guys, got it solved, the problem was, the mobo user guide says sata conectors 1-4 are for RAID, and 5-6 are for IDE & eSATA, but the illustration in the guid book is wrong so when you look at the markings on the motherboard 4 & 5 are the wrong way round as 1/2/3 are side by side and 4 & 5 are stacked one on top of the other if you sea what i mean.
(port 6 is at the rear)
Anyway thanks for the help guys.
