*SOLVED* Ethernet port not active
18 Apr 2016
Hi all,
I've just had to reset my computer to factory settings and it deleted a load of my files.
Since this, my ethernet port no long works on my motherboard?
It's a Z170M Mortar MOBO, the onboard LAN in the bios is set to enabled but it no longer works?
I'm at a complete loss and need some help!! :(
Thanks
How are you ever meant to get the drivers if you don't have a ODD drive
