so I finally got round to sorting my skylake system out, I purchased crucial ram the other day for clearance of my cooler due to vipers being too tall, anyways they are 2 single 4gb sticks as I needed to test the fit with my cooler, felt no need to buy a single 8 gb after the success, but all is not what it seems and I can’t tell if it’s hardware or software related.
So bios reads 4gb not 8, task manager and ‘about’ lists as 4gb too although suggests my board has 4 dims when it doesn’t
, so i installed cpuz and while it says single channel it does say I have 8gb and options to see both installed memory? Now the other strange thing is the ram slot near the cooler doesn’t seem to give visual on boot yet does with both sticks in
, so I’m confused whether I’ve got hardware issues or I need to try get it to run in dual channel if that’s even possible?
It’s the gigabyte H110M - S2H motherboard and ok using a i3 6100.
, so I’m confused whether I’ve got hardware issues or I need to try get it to run in dual channel if that’s even possible?It’s the gigabyte H110M - S2H motherboard and ok using a i3 6100.
