Some advice for quiet gaming machine
21 Jun 2010
Hi, this is my first post so forgive any important omissions.
I'm putting together only my second ever build and I was hoping for some advice before I take the plunge.
I currently have a budget of about £800 and am looking to build a quiet, reasonable gaming machine. I will be recycling my current 9800GT graphics card, HDD, DVD drive, peripherals and monitor.
I'm currently in a SFF and want to upgrade to a larger case to allow easier upgrading in the future, a solid mobo and chip to avoid any replacements soon, and enough RAM to happily play with for now.
Since I have no overclocking experiance I had opted for below
I will upgrade my graphics card in about 3-4 months as funds allow. And intend to upgrade to SDD too. But these will be future projects.
Is there a better option for my needs? Would an AMD chip, in a similar OCz bundle also suit my needs of gaming/ no upgrade for 4 years.
I realise the Fractal case is probably over the top for my budget but I wish to keep it for a long time and it is just so pretty. But I know from reviews it will run warm. Will extra fans be needed and what brand/model of fan would be best?
Any help is greatly appreciated.
Would it be better learn to overclock later and buy the bits seperately? I know that would be cheaper.
Is AMD or Intel easier to overclock at the moment bearing in mind I've never overvclocked anything in my life.
althou its cheaper, it might be better just to get a prebuilt one, as it will save u some hassle if you not that confident to do it urself.
at lesat then u will have a base that u can learn to overclock from so next time you plan to upgrade, u can get the parts seperatly.
unless ur budget is really tight of course
Get an Antec p183 case, bit more expensive but quiet. Or a HAF X from Coolermaster, uglier and bigger but quiet...
I had the P182, most quiet case I ever had, can be gotten for about £100?
Cheers
Von
A mate of mine has the Fractal Design case and it's pretty much silent, no complaints on that one.
Antec 182 is very quiet, but doesn't look as good as the Fractal IMHO (I used to have the p180)
You could probably get a cheaper PSU (e.g 550w) if money is much of a consideration. That Corsair is nice though
I would say that AMD would be a better route to go if upgrading in the future is a priority. The new intel cpu's (sandy bridge or whatever they will call it) will use a different socket (LGA 2011).
For gaming very few games fully utilise all 4 cores. If you google phenom ii unlocking you could pick up an X2 555BE and still possibly get an X4 with a minor change to the bios settings. When games start to "catchup" with the tech you can then upgrade to a newer AM3 CPU.
Give it some thought! If you ask stulid very nicely he may spec you a system. He has a genuine nack for it and all the rigs i've seen him suggest are well thought out and excellent value for money
Not really sure what in that build is supposed to be 'quiet' :P overclocked bundle and 9800gt lol I assume by quiet you just mean not excessively noisy, because if you want quiet, then fanless gpu + psu, SSD and underclocked cpu with the fan turned down (or watercooling) are the ways to go.
That lot is obviously going to noisier than your standard use 'off the shelf' type PC, as long as you reallise that! Other than that will be a nice little gaming rig.
Yeah what I don't want is the sound of a small plane under my desk, on the other hand I realise it's not going to be 'silent' by any means.
So do people think it would be better to go for a Phenom, and learn to overclock at some mystical point in the future when I actually need the extra umph?
I just got (about 1 week ago) one of those R2 cases from OCUK and it had a note from fractal inside saying I should change the usb case cable for a new one (also supplied). As an apology, they included a 3rd fractal 120mm fan for free, so if yours is the same, you'll actually get 3 fans with it, not the advertised 2.
I added one of these :
http://www.overclockers.co.uk/showproduct.php?prodid=FG-002-ZA&groupid=701&catid=57&subcat=4
As the 4th fan. (You really have to use the supplied low voltage cable for it or it is too noisy).
As you can see, I'm using the Coolit ECO, which is very similar to the Corsair H50. Like the H50, it comes with it's own fan. I used 2 of the fractals for intake at the front of the case, 1 in the roof for exhaust and added the Zalman fan onto the radiator as the 2nd fan.
Firstly thanks for everyone's help already.
SO if I branched out and decided to get parts would this work? (bearing in mind I don't need HDD/GPU/CD/DVD)
Could I pick better parts in same budget? I'm assuming I can overclock with that board if I want to later.
Also if you had £150 to spend a graphics card for this what would it be?
Thanks again.
If I had 150
4 cards would spring to mind.
5770 have some money spare
5830 almost exactly 150
4890 powerful no dx11 power hungry
460 exactly on budget.
GPU fits your requirements and case is ultra quiet.
e.g GPU for £150 and a nice quiet case.
Nuff said.
Sorry to bump this up again asking more questions.
RE Motherboards, I picked the Asus P7P55D-E LX Intel P55 http://www.overclockers.co.uk/showproduct.php?prodid=MB-394-AS
as it was what OC uses in their bundles(steal from the best)
The Gigabyte GA-P55M-UD2 Intel P55
http://www.overclockers.co.uk/showproduct.php?prodid=MB-209-GI
is cheaper and has excellent reviews in terms of overclocking.
I know you often get what you pay for but which board do people think is best, bearing in mind this spec
Intel Core i5 760 2.80GHz (Lynnfield) (Socket LGA1156) -
OCZ Reaper Low-Latency 4GB (2x2GB) DDR3 12800C6 (1600MHz) Dual-Channel
Fractal Design Define R2 Midi Tower Case - Black Pearl
Corsair H50-1 High-Performance CPU Watercooler
Corsair TX 650W ATX SLi Compliant Power Supply
