Some Advice Please.
21 May 2010
Digbeth
So, I own a HD4890 with a nice tidy Zalman HSF thingy. Only problem is, at lower than stock speeds its getting VERY hot. Fan on 100% (is any-way as its 2pin) and card doing 80% work, I'm hitting 110-C on the temps :eek:. This is worrying as I own a HAF 932 with the side, front and rear fans on 100% thus creating a lot of air-flow. Now I'm thinking this is way way way to high. I have re-seated the HSF a few times now and it's not really doing anything. Anything else I can do for it guys?
That is hot, my 4890 dont even touch 80 under heavy gaming :eek: do you have heatsinks on the vrm`s, perhaps they are getting hot, what thermal paste are you using??
Yes I do, and it's got the cool-labs liquid metal on it atm. Waiting for some IC Diamond 24Carat from OCUK, will do a re-seat with that, but I'm not expecting anything :(
It sounds like it could be on it`s last legs if it just started overheating! what software are you using to monitor the temps?
where does it exhaust from, cause i am sure you would be able to feel the heat physically? not sure what the thermal envelope is for the 4890, i have read some post about it poss going to about 120c, though not sure. Hopefully some-one who knows a bit more about this will reply.
Into the case, and yes, its gets VERY warm....
Sorry Jaffa cant think of nowt else it could be. Normally the steps i would do would be to check the things you have done. i normally use gpuz to monitor temps as it shows all the temps on the card, that way you might be able to see whats getting hot.
Um...looking at Gpuz, get ready!!
GPU TEMP (DISPIO) - 100-C
GPU TEMP (MEMIO) - 125-C
GPU TEMP (SHADER CORE) - 115-C
Surely the memory shouldnt be THAT hot?
time to rma if you can? if not i would take it apart and put some new arctic silver or what ever you have thats way way to hot, i would not even use it until you get it sorted.
If the heat sink is getting burning hot then its doing it job and you need to look at how the heat is being removed from the case.
i think he should see temps with stock fan again.
This is the stock fan, it came with the Zalman aftermarket fan allready, from the shop.
Also I would RMA, but im off work sick for a week with bronchitis, so I need it to keep myself sane :(.
Will re-seat AGAIN when my IC Diamond arives and have a jigger about with it all to see if the seperate sinks are loose/not contacting.
WOW.........That is toasty!!
Mine is,
GPU TEMP 59C
GPU MEM 60C
Shader core 57C
I reckon the card must be borked, has it not shutdown with a black screen yet?
Mine is,
GPU TEMP 59C
GPU MEM 60C
Shader core 57C
Nope, its shut down many times with massive artifacts sometime BSODing with an ATIKMDAG error, and took forever to reboot, acting like a throttling CPU....
If you did rejig with the IC Diamond, would this void warranty and then you would not be able to rma?
