Some help converting ASP to PHP
13 Nov 2003
Manchester
Hi All
Could someone help me out by converting this code into PHP. I am not familiar with ASP so not too sure how this code is working
Code:
<% originalproductcode = Replace(Left(recFroogle.Fields.Item("productcode").Value,Len(recFroogle.Fields.Item("productcode").Value)-3),".WP.","#")%><%=originalproductcode%>
I can change all the database stuff, not the replace section though.
Thanks in advance
Aaron
Any takers on this? I can do a standard replace in PHP but this one doesnt look standard. Its the '3' bit that confuses me
Thanks
EDIT
Looking at what the code needs to do, I dont think the '3' bit is required. The following code does the trick
Code:
$product_code = str_replace('#', '.WP.', $row['productcode']);
