Hello. For the last week i've noticed my internet connection dropping / being slow. I did a speed test and instead of 200mb that im suppose to get.. i get 9.
I've contacted my isp (virgin media) and they said theres no faults on the line but are sending someone out in 3 days to check my home out.
Its slowly getting worse. If i download something i have to cap it to 500kbs otherwise my internet will die and i will need to restart the computer (not router) to get the internet back on.
Last night i was downloading and streaming but i kept blue screening...
On Sat 25/02/2017 21:33:04 your computer crashed
crash dump file: C:\Windows\Minidump\022517-5943-01.dmp
This was probably caused by the following module: hal.dll (0xFFFFF80002E057F7)
Bugcheck code: 0xA (0x8, 0x2, 0x0, 0xFFFFF80002E057F7)
Error: IRQL_NOT_LESS_OR_EQUAL
file path: C:\Windows\system32\hal.dll
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
crash dump file: C:\Windows\memory.dmp
This was probably caused by the following module: l1c62x64.sys (L1C62x64+0x6F27)
file path: C:\Windows\system32\drivers\l1c62x64.sys
product: Atheros Ar81xx series PCI-E Gigabit Ethernet Controller
company: Atheros Communications, Inc.
description: Atheros Ar81xx series PCI-E Gigabit Ethernet Controller
On Sat 25/02/2017 20:29:16 your computer crashed
crash dump file: C:\Windows\Minidump\022517-5491-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x6F3D0)
Bugcheck code: 0x1E (0x0, 0x0, 0x0, 0x0)
Error: KMODE_EXCEPTION_NOT_HANDLED
file path: C:\Windows\system32\ntoskrnl.exe
description: NT Kernel & System
On Thu 23/02/2017 22:22:21 your computer crashed
crash dump file: C:\Windows\Minidump\022317-6021-01.dmp
This was probably caused by the following module: ndis.sys (0xFFFFF8800159C420)
Bugcheck code: 0xD1 (0x0, 0x2, 0x1, 0xFFFFF8800159C420)
Error: DRIVER_IRQL_NOT_LESS_OR_EQUAL
file path: C:\Windows\system32\drivers\ndis.sys
description: NDIS 6.20 driver
Any ideas? I've tried to update my network drivers and it seems fine.
I've tested my speed on my mobile over wifi and im hitting 130mb. Its just the computer thats having problems.
Whenever the internet dies, i have to reboot the computer. So as i dont have to reboot the router.. i guess thats not the problem?
Virgin tech are coming in a few days so maybe they can help.. but thought i'd try on here also!
One thing to mention.. i have played about with safeip (vpn) but now its deleted so not sure if thats changed any settings.
Any help would be greatly appreciated!!
