Hey, i have 3 good cores and one faulty because when i unlock all my cores and run prime i get an error on one of the cores and it stops being tested for some reason, is there anyway to unlock one core and have a tri core and lock the bad one out?
I am using this MOBO: Asus M4A785TD-V EVO
which core is the bad one....3 or 4?
You can set windows to only boot with a set number of cores to be seen by the OS, although the bad core is still active, windows and any apps or games that you run will be tricked into thinking you have 3 cores and so only use the good ones.
What OS are you using..?
