I have a 4 yr old PC, and it has always been too noisy. I'm looking for a fix. I'm no expert with computers so I may have overlooked things here.
My setup is:
- CM 690 - Cooler Master
http://www.coolermaster.com/product.php?product_id=2908
- Coolermaster 460W Dual 12V Rail Power Supply
- Intel Core 2 Quad Q9550 CPU
http://ark.intel.com/products/33924...cessor-Q9550-(12M-Cache-2_83-GHz-1333-MHz-FSB)
- Arctic Cooling Freezer 7 Pro
http://www.arctic.ac/en/p/cooling/discontinued-products/cpu/266/freezer-7-pro.html
- Gigabyte GA-EP35-DS3R Motherboard
http://uk.gigabyte.com/products/product-page.aspx?pid=2743&dl=#ov
- nVidia 8800GT 1GB Super PCI-E Graphics Card
http://www.pcstats.com/articleview.cfm?articleID=2255
I bought the PC overclocked (from 2.83 to 3.2), but the OS has been changed since. By looking at a CPU-Z test, I'm not sure if it is still overclocked?
I use the PC for 3d graphics, so it gets put under load when rendering. I think that there is 1 fan in and 1 fan out on the side, and 1 fan out on the back. I'm not sure if this is setup correctly?
I've attached a screenshot of the CPU-Z test and also one of the fan speeds, when idle and when rendering (the room temperature was probably 15-20 degrees C).
I'd be very grateful if someone who knows what they are doing would look through this info to see if anything is out of place, and recommend a solution.
Thanks
My setup is:
Thanks
