Hi,
I just started overclocking for the first time, i read the sticky in the forum. And have gone up to 474x7 and x2 on the ram.... im running @ 3.318MHz atm. Thing is when i set my voltage to 1.37500 or what ever it doesent boot into windows. But when i set it back to the setting normal under cpu voltage it does. Temps are around 50 atm with fan on full speed so i think i can get a bit more out maybe 3.6 mark
running orthos. I have all the voltages set to normal.. but if any one can help me get this set up properly it would be great. Also my ram says it is 900MHz in bios is this ok ? i havent changed any voltages btw
Thanks.
EDIT done a screeny for you all..
.Thanks.
booted into windows and running orthos agen.
. If its reading right im basically running my CPU on near enough stock volts at 3GHz
