- 11 Oct 2005
- Derbyshire
I know some of you wont like my car, but fair enough I just need some advice.
I have a W reg Renault Laguna 1.6 Alize. Had it since new and has done 104k miles.
the clutch cable snapped last week and my mechanic sorted it (£130, which included £60 recovery charge as I was about 12 miles from home) but told me clutch is on way out. Could last 3 - 4k miles but he was not sure.
Driving home tonight from work it is going. Have all on getting a gear. Cannot get 1st unless I switch engine of, put it into 1st then start car and it starts to move off even with clutch pedal all the way down. Same in reverse. Very hard changing gears.
Now my mechanic told me (used him for years, he is good) New clutch £300 plus it needs a front left hand wheel bearing £70 and MOT on 24th July.
I don't have the money to change the car really for something else. so I am looking around £400 ish to sort my car.
Is it worth sorting ?
Or should I just cut my losses and buy a cheap car for that sort of money or what. Everything else (I think) is ok on the car.
Does my head in as you rely on your car so much and this will put me in a big pickle with regards work. But I can still get there as I have a motorbike but only recently passed motorbike DAS test and don't really want the bike for riding in the wet.
Just posting here to see what the people in the know think.
Thanks
Thanks
