Some Visual Basic Help Please
3 Aug 2006
London, UK
Having trouble with my VB Project again but google has failed me.
Is there any way to distinguish between Letters and Numbers entered into a textbox without limiting it to one or the other?
Basically, i have a text box where users can enter a code to find an item and I want it to look up two different sources depending on what is entered
e.g. if a text code is entered, the code checks the database for a line which uses this ItemCode.
If a barcode is scanned in (all numbers) then it should look under the Barcode field instead
Any help greatly appreciated
Cheers,
Mitchel
