someone please explain.....
9 Oct 2009
Leeds,UK
Why if i change fsb to 210 and multiplier to 16.5 giving 3465 clock speed it is not stable (temp never above 52) and resets after about 20 mins of full load, but if i run fsb at 200 and 17.5 multiplier giving 3500 clock speed it runs fine (same temps)?
I have to ask why complain about a 3.465ghz overclock being unstable when you can get a 3.5 ghz stable overclock!!!
Looks like you need more volts if you up the FSB but not if you up the multiplier Iwouldn't fuss much
edit:woo 400 posts
i been askin the same question myself on another forum.the fsb adjusts other stuff like n/b, ht link and ram. u hav to set these lower before u adjust the fsb as they will go up automatically when u adjust the fsb.3.4gbz should not require a voltage bump.i been benching an a fsb o/c gives u more perfomance than a multi plier o/c
The issue is lack of knowledge of the overclocker. I recommend reading more about the process before continuing.
+1 Indeed
Like someone else said changing your FSB or bclk changes a lot of other things also which would cause things to become unstable.
Thanks and i agree I am completely new to this. Ive been doing a bit of reading and playing around. Ive got the Ram under control and the HT link is nowhere near the 2600 max as its set at 10x FSB. There seems to be a lot of info regarding CPU and RAM but not much for NB or HT Link. Ive now updated bios so that i have option to change NB multiplier.
How can I monitor NB temp? Is that the motherboard temperature shown on PC Probe & HWMonitor?
