- 5 Apr 2014
active floor standing
They will work, but don't expect the DM39 to drive them with plenty of power. It's rated at 30w into 6 Ohm. BX5's are 8 Ohm with a 30-120w amp recommendation.
Well that's the beauty of an integrated amp, as they have 5 or 6 inputs, you connect various devices to them. Whether it be a CD player, a DAB radio, a DAC (digital to analogue converter) so you can connect a digital source up. In the case of a DAB radio, you'd need one with analogue audio output to connect to the amp. Same goes for a TV, it would analogue RCA audio output.
Maybe an AV receiver would be a better option, as they have digital connections as well as analogue, so if you have a TV with optical output only, you wouldn't have to worry about external DACs. Although you could probably just HDMI anyway. Not sure about DAB tuners though. Many have AM/FM listed in the specs, but I can't see DAB mentioned. Not even on more expensive ones.
If you've got a smartphone or a tablet, you could use that to stream internet radio to it. I've done that with my phone, streaming radio to a Blueooth receiver connected to my amp. Having said that though, doesn't look like any budget models have Bluetooth, although connecting a cheap Blueooth receiver is no problem.
