Something like Live Mesh for local networks?
31 May 2005
Nottingham
Does anything exist?
Need to synchornise game folders with mods etc across local network so as I add mods to my gaming PC, they will automatically update on another PC without having to manually copy/paste.
Thanks.
I use Vice Versa to automatically sync/backup my stuff to another PC. Works well in conjunction with the scheduler they have also.
It can detect changes and automatically sync across so all you need to do is download on the one machine and it will proporgate the changes to wherever. It's not cheap (about 70 quid for the software and scheduler) but I looked around and this was the only one that worked properly. I'm sure there are fancier ways of doing it, but for windows 7 to win 7 machines for me this was the easiest
Mmm...
I have tried the above software but only allows to upload to one specific folder.
I am trying to share game saves across multiple PC's so need to be able to specify different folders on remote PC's for different file transfers, i that makes sense?
Kind of like a local version of Steam cloud.
why cant you do it via the net, and use dropbox ?
Your dropbox folder can only be one location.
I need to create multiple "jobs" for different games with them going to a different destination.
It only allows one source for files as well.
Wont live mesh do this? I use it to sync my docs folder, work docs folder and photos folder across 3 different PCs. Latest version even back ups the files to online space as well.
if you mean, that the dropbox folder only syncs things within that folder, there is a fix around that lets your sync files anywhere on your pc
if you read up in the dropbox forums, youll see it..
Could try Windows synctoy.
THANK YOU.
That is exactly what I needed, does exactly what I want.
Such a small and simple idea for an app but perfect for what I need.
Surprised they have not built that into Windows as a feature.
What I need to do for example is synchronise C:\Steam\Saves\Meatboy on PC1 with C:\Steam\Saves\Meatboy on PC2... I then also wish to do the same with C:\Steam\Saves\Bioshock...
I was not sure Dropbox would allow me to setup multiple folders to synch to at the same time, i.e set more than one target folder.
