Something's wrong
5 Apr 2009
West Midlands
Last night my CPU cooler (Arctic Cooling Pro 7)'s fan started going as fast as it could. I could hear this. Not a problem I thought. I checked on Task manager and the CPU was idle. About 30 seconds later PC knocked itself off. So I booted it up and it said CPU temperature overload or something along those lines. So I tried to get into BIOS, the fan still running as fast as it could and removed my 340MHZ overclock. (Just upped the FSB) So I took the FSB back down, saved it and then it knocked itself off again, still, the same problem.
I haven't looked inside the comp yet, as it is a pain to get it out. I just don't understand how one second it was fine and the next minute something is up.
Any ideas anyone? Is the CPU actually getting so hot it has to turn itself off, or is it just a bug?
CPU - Intel E8400
Mobo - Asus P5Q SE
Cooler - Arctic Cooling Pro 7 (Bought over a year ago)
The AC Pro mounts via push-pins, doesn't it? It's possible it wasn't mounted quite securely in the first place and has come loose. I found the push-pin system on skt775 a right pain, and replaced my old cooler's pins with a backplate mounting mechanism.
Can you see the CPU temp when you're in the BIOS?
Fixed. Absolute embarrassment. The heatsinc had come off. :(
Sorry guys, cheers for help anyway.
Same thing happened to mine with my Intel reference HSF.
Hate the push pin type system. Never can be sure if it is down properly or not.
Same thing happened to me as well when I fitted my intel HSF. I'm amased it didn't die either. Thank god that CPU's/Mobo's know how to save them selves from death!
