Sonicwall TZ210 and Virgin Media
  • Thread starter Thread starter Ish
  • Start date Start date
Ish
Ish
11 Jan 2006
West Midlands
Hi
We just had the VM 100 meg service fitted. Using just the VM superhub we were getting 70meg down/10 meg up.
Once the superhub was put in modem mode and connected to the Sonicwall the speed has dropped to 15meg down/10 meg up.
What could be causing this?
The TS210 has the following spec
Feature Value
Stateful Throughput3 200 Mbps
UTM Performance4 50 Mbps
Gateway Anti-Virus Throughput4 70 Mbps
Intrusion Prevention Throughput4 110 Mbps
If you have all the UTM stuff turned on, that may be about right - given that performance figures are always hugely optimistic for the real world
That firewall isnt properly sized for a 100mb connection
MTU size on the WAN port? Throughput will be dire if it's still set to 1500.
It is set to 1500, what should it be?
Feature Value
That's a shame having to lose 40 meg of download :(
Depends what services are enabled, packet size, other load etc etc
But really you need to think about these things before upgrading internet connections - bigger firewalls should be part of the business case if they are needed
