I have just bought Sony PSHX 500 and intended to play through a Cambridge Audio Azure 540A amp. The sound is mega muffled - we are into 'not working' territory as opposed to sub optimal. The turntable has a line out function which in theory means no preamp needed. I have tried connecting this function into the equivalent line functions of the amp - no joy. I tried using the phono option - same result and used a grounding wire. It's a brand new turntable so unlikely that it is broken.
It is an old amp . Do we think that despite the turntable having a line out function that I still need a pre amp? My understanding was a preamp deliver better sound rather than simply makes the thing work.
One final strange thing. The amp works with everything else. The CD player works well on CD mode and if you push another button (say 'DVD') the sound goes off as you'd expect. With the turntable, the really bad sound comes through every button on the amp. Hope that makes sense, hard to explain.
