- 25 Nov 2011
- The KOP
It is somewhat possible the gpu is taking some of the load, my GPU says a max of 17% usage when I try rendering with Sonys codec, still though CPU utilization is 70% or so. Rather than 30% usage and 80% usage on SLI GTX 460's
Sometimes I wish I hadn't upgraded
I use either.
WMV @ 720p 30.00 FPS
1.000 Pixel Aspect
0 Video smoothness
8M bitrate
Best project settings
2048x1152 WMV
1.333 Aspect
100% Vid smooth
12 MB bitrate
720p / 1080p M2TS w/ GPU, mp4 buggers up after 70% or so
29.970 FPS
1.0000 Pixel aspect
15MB bitrate
Best project settings.
Examples:
Ok thanks will check them out. When you upload with WMV, does it take you twice has long? Because Youtube converts it into MP4 anyway.
