From what I remember from the initial reviews - the S22+ was the lemon of the family - you were better either just sticking to the standard S22 or going the whole hog and taking the Ultra as the battery life on the S22+ was pretty poor. Whether there's been any improvements since then I'm not sure.
I always liked the idea of the Sony Xperia phones but always felt disappointed both with their crazy soft launch/real launch schedule differences and the general support afterwards hasn't been great.
Mainly battery life was the main reason yes
If you're using the phone for photography then I really would recommend saving a bit longer for the S22 Ultra - the cameras on it as many will tell you in the S22 thread are awesome!
As a 6 Pro user, I've been very pleased with low light images. If photography is important then it's worth waiting for more detailed 7 Pro photo reviews. Otherwise the S22 Ultra is not that far behind. The normal 7 is worth considering too if you don't need the telephoto lens, and it'll have the flat screen.Cheers, it's a business contract with a hardware fund so money isn't an issue, but I still don't want to 'overpay' for something I may not need. The ultra cameras do look great, although not sure it would be enough to offset the curved bevel screen thing that I don't like. I'm wondering if the Pixel 7 Pro is worth waiting for? The Pro 6 low light looked pretty poor.
