Ive got an external sata to usb hdd enclosure. I have it plugged into a USB switch with two controlling devices connected:
my doovde player which has a USB port (this works fine through the switch)
my pc, so that I can put files on the external from the pc (does not work)
The problem is that when the external drive is connected through the switch to the pc, windows has problems with it. It either says its working ok in device manager but there is no drive letter in my computer, or I get a message saying that there is a problem with the device (a baloon pop-up when windows tries to install).
Ive tried different usb cables and no joy. Any thoughts?
[edit] the external enclosure works fine when directly connected to the pc (i.e. not through the switch)
