Sorry, another will it fit....?
18 Oct 2002
Got a Coolermaster 201B (Black Widow) Will the 8800GTX fit in this case?
I've checked the compatible case site but it's not listed on there. Does anyone know if it will fit in this case?
Cheers.
The 8800GTX does fit in a 201, though only about 10mm spare between end of card and drive cages, which means if you have drives right where the card is it will be a very tight squeeze!
The internal on the 201 is the same dimensions as the wavemaster
Just a case of moving the HD's then, the extra power connectors are on the side of the GFX rather than the back aren't they?
