Sorting out my decking... tools
31 Jul 2004
Surrey
My decking is in a bit of a state, I used decking restore to clean it up yesterday and now I want to sand it down.
There's about 60 square meters so I'm not doing it by hand, just tried using my electric sander and its not having it so I thought about a floorboard sander??
What do you think? Like the ones HSS do for sanding wooden floors?
Would it work? Can't see any reason why not..
Personall y I hate decking. But if it's anything like the decking in my garden (about to rip it up!) then it wouldn't work. My decking is grooved to stop people slipping in the wet and a floor sander would not get between the grooves.
it is grooved, I want to take the top layer off though, not fussed abut getting into the grooves [/madonna]
Got the same problem myself.
You think they would make some decking stain or something you can just put over the top.
I coloured mine (brown) using some decking stain, but its peeled away after a few years and instructions say its got to be completely sanded down.
Tried doing by hand and using a sander and a total disaster.
I ended up re-spraying ontop of it, it lasted a year but needs doing again now.
Really want to completely sand it all down..
hire an industrial steam cleaner and give it some point blank with that baby
should come up lovely :D
Don't use a finish thats going to sit on top of the wood as this will peel or wear away after a while. Use a stain that will soak into the timber to protect it and keep topping it up once a year.
Id have thought a floor board sander would do the job but it depends what the finish is like. If its all gummed up or damp it will probably just keep clogging the sandpaper.
not its completely clean and I won't do it unless its dry.
A hand sander is doing the job but there's loads of it, it took me about an hour to do a square meter and there's about 50 or 60 of them.
Personally I'd rather not have the stuff but the previous owner put it up and I guess if I can fix it it'll look good.
It still might start clogging up depending on the finish, much like trying to sand hard glue... once you get going it'll just clog the sandpaper
give the hand sander a whirl and see how it copes, then try a bigger one.
depending on the new finish it might only need a light sanding
Its not just the dirt, the finish is quite rough too so I'm wanting to smooth it off.
Although to be honest the wood is so stained I doubt the pressure washer would make much of an impact.
