Sound Blaster Live! 5.1 +external headphone/mic connectors
7 Jun 2005
SE London
Is it possible to connect external headphone and microphone connectors (e.g. built-in at the front i/o panel of a case) to this card? (rather than using the connectors at the back of the card itself)
get an extension wire...
then have it round the side of your case and use that?, i used to have one but now i have speakers with a headphones socket in them so no need.
well having a 2m extension cable wouldnt be at the front of your case? or do you need it that extra 10cm off the floor so its that much easier??????????
Yes. I have an extension cable, but i want to use the front plugs in my case.
