1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Sound fading in and out R1800TIII 2.0 Studio Speakers RMS 70 Watts (R1800TIII) please help
Discussion in 'Sound City' started by Peter_b, Feb 7, 2019.
  1. Peter_b
    Hi I got these speakers a few weeks ago and the sound is fading in and out as if im constantly changing the volume up and down.
    Ive tried them on my sound card , onboard sound and through a phone and dab radio all with the same problem any ideas ?
  2. JasonM
    Wise Guy
    If you have tested with multiple line inputs, then it's probably the speakers faulty.
  3. Marsman
    Capodecina
    As Jason says, it's likely the speakers if you get the same with multiple sources.
    Probably worth trying a different cable (if you have another you can try) to connect the sources you are using, just to rule that out.
    Have you tried using both inputs on the speakers, as they have dual RCA input?
    Assuming using another cable and both inputs results in the same problem, then send them back.
