Sound in game gone quiet?
27 Mar 2016
Bristolian living in Swindon
Hi all
Today I upgraded my wife's systems CPU only and now shes complaining when playing PUBG the sound is very quiet yet everything is turned up to 100,
In game 100
Headset on desktop setting 100
Headset volume button up to 100
Any predictions as to what else I can try please to keep her off my back :cry:
send her for a hearing test :cry:
is it only that game?
youtube etc ok?
check loudness equalisation is on in audio mixer/enhancements
I should as that plane on PUBG is louder than most things :cry: No its everything she said, I checked on the mixer etc all turned right up, Made sure the Jacks were in correctly,could it be driver related maybe??
anything installed like asus sonic studio
or realtek audio manager?
those have a smart volume/loudness setting in them
it makes a very big difference to my volume levels
you said headset volume 100
so that rules out my other suggestion
mine has touch sensitive volume and wouldnt be first time
i have accidentally turned the volume down yet spent a while
trying to fix it in windows
wouldnt totally rule out the driver i guess
uninstall and reinstall it would be an option if nothing else works
edit
would also suggest test on a different pc/device
to rule out the headphones
How can I adjust stuff in Realtek? I do see that on her sound settings, Her headset has a dial turn adjust the volume, it's a Razer Headset... I tried it just now it's not really quiet but you can't really tell where enemy movement is unless it's completely silent
realtek hd audio will be in control panel
if your device is using it-- i switch control panel to icons not category to see it
though this pc has sonic studio so doesnt have realtek hd audio
if you have sonic studio or other manufacturers sound software
then realtek hd audio wont be in control panel
never used razer so dont know if theres also a software
that goes with their headsets
though if there is and its not installed anyway wont matter
since wasnt there before the issue
