Soundbar - 3.5mm to Optical cable
28 Jan 2011
Hey guys,
Might be buying a decent sounder from a relative..
Im wondering, if there is no 3.5mm port on the soundbar, can I use a 3.5mm jack (from the Mac MINI) to a Optical (into the soundbar)?
Or anything similar I can try?
Maybe a USB C to Optical adapter?
Cheers.
Which Mac Mini model is it? A quick search shows starting from 2018, Apple removed optical support from the 3.5mm jack so a normal 3.5mm to optical cable won't work.
USB-C to optical should work but no idea what will work with the Mac Mini.
Its the 2020 Mac mini M1. Thanks for the input, will see how I get on, least know now to try USB C to Optical if the cable on its own won't work.
Cheers.
Well, I think the soundbar (will confirm tomorrow) does NOT have a 3.5mm AUX port..
I was thinking of adding a sub to it, quick question please, if I buy a sub with red / white rca female inputs, and the soundbar only has a single rca, can I buy an adapter, to have 2 male (for the subwoofer) and then split to have the single male in the soundbar output?
if that makes any sense! :)
Well, got the soundbar today, and it does have analog connection, sweet!
I’m going to buy the matching subwoofer for it, will a standard single RCA be ok for the connection to sub and soundbar?
YAS - 107 Soundbar, now setup..its got nice bass, which is making me think I don't "need" the sub? What do you guys think?
(Also im thinking of covering the blue LED on the monitor, its a superb monitor, but that LED does tilt me a little..).
