Hi folks,
I have had the SP2500 speakers for over 5 years now, and whilst great, they have developed an annoying hiss at all volumes (even zero). This hiss is present regardless of the input, or in fact no input. It is not really bad by any means, but sitting a meter away you can notice it as soon as the unit is turned on, but it is a sound that you get used to, although annoying.
So anyways that got me thinking about an upgrade as the wife often complains of the microwave size sub taking up space on a bookshelf.
Primary use is music and gaming. I have a AE-5 sound card and want to stick with 2.1. Any recommendations. I want to get value, but do not mind spending to get a good set that will do for years.
Thanks
Thanks
