- 3 Jun 2005
- The South
Is there a way of using the line out of the Squeezebox and connecting to my amp and speakers without a wire?![]()
Something like the JBL WEM-1 would work; Rocketfish also do something similar. Alternatively bodge it with a video sender of sorts. But it all sounds a bit messy just to use a Squeezebox. Can you not mount the Squeezebox near the amp?
Alternatively, and cheaply (could even grab a 1st/2nd gen from the bay), you could create a headless music front end using a ATV with XBMC installed and just use the Android XBMC remote.
