I am just measuring up where everything is going to be in my new living room based on the furniture being used.
I have calculated that my front (2020i's) and centre speaker (2000Ci) will be 61cm from the floor and the bottom of my TV (48H6400) will be 78cm from the floor. This is based on the TV unit being 61cm high and the centre speaker which is having to sit on top being 16cm high.
With this in mind at what height should I wall mount my surround speakers (2010i's). I am thinking that the bottom of the speakers should be higher than the fronts and am thinking of having them just above the top of the sofa that will be along the same wall. The Sofa is 84cm so I was thinking setting the bottom at 100cm.
Any advise welcome.
Any advise welcome.
